1986 Other Toyota Models Coolant usage
1986 TOYOTA
240,000 MILES • 4 CYL • 2WD • MANUAL
COLUMBUSCUPCAKE
Truck goes thru 1 USgal of water per day -- NO leaks, NO water in engine compartment, NO nothing. But it does have the white creamy film on the oil cap.
Worth fixing?
Apr 20, 2009 at 10:25 AM
SERVICE WRITER
  • 9,123 POSTS
Depends on the cost of repair. If the cost is less than what it would cost to replace the truck with the same things it has, then yes. If you can find less expensive transportation then no.
Apr 20, 2009 at 10:29 AM
