High idle problem
AWALE
My car is a 1989 toyota MR2. 2000cc 1G-GZE engine.The vehicle started problems with high idle after a long trip where i lost temp sensor and a cracked vaccum hose. I bought new sensor & hose,cleaned all vaccum pipes & cleaned throttle body.Now it idles upto 2000rpm,gears shift late & generaly doesnt pick speed quickly nor drive smoothly. When i step on the gas pedal,the supercharger doesnt come on,instead check eng light comes on &power decreases
Jul 17, 2007 at 10:40 AM
  • 75,988 POSTS
[quote:a755e0dcff="awale"]My car is a 1989 toyota MR2. 2000cc 1G-GZE engine.The vehicle started problems with high idle after a long trip where i lost temp sensor and a cracked vaccum hose. I bought new sensor & hose,cleaned all vaccum pipes & cleaned throttle body.Now it idles upto 2000rpm,gears shift late & generaly doesnt pick speed quickly nor drive smoothly. When i step on the gas pedal,the supercharger doesnt come on,instead check eng light comes on &power decreases[/quote:a755e0dcff]
You need to find out what code/s is it, before we can help you.
You could start by cleaning out the IACV and also check the TPS/MAF sensors-inspect the Acc. cable.
Sep 10, 2007 at 11:29 AM
