1992 Toyota MR2 sitting 9 years
1992 TOYOTA MR2
SKAPCOMO
Other Category problem
1992 Toyota MR2 Engine Size unknown Two Wheel Drive Automatic 60000 miles
friend has this car and it been in an unheated garage since 1998. Not started once. How do you check it out to see what's good and what needs fixed?
Dec 21, 2007 at 2:07 PM
BLACKOP555
  • 10,386 POSTS
first of all, the whole fuel system will have to be drained and replaced with new fuel and more then likely you will need a new battery.. then disconnect the ignition coil and crank it a few times and then reconnect the coil and see if it starts up.
Dec 22, 2007 at 12:34 AM
