is it normal to here a grinding sound when shifting from four low back into four high?
Sep 23, 2007 at 4:22 PM
Shift between 4-low and 4-high only while fully stopped. Grinding means the range selector is being moved while the vehicle is moving, which can damage the transfer case because that shift has no synchromesh.
The owner of a Toyota Land Cruiser asked whether a grinding sound when shifting from 4-low back to 4-high is normal. The expert said the shift should be silent if done while stopped, and that shifting even while moving slowly can seriously damage the transfer case because the selector slides between gears with no synchromesh.
