Hi markad,
Sorry I am a bit confused.
The engine cranks but would not fire up because the distributor is not supplying any sparks to the plugs?
There is no current supply (battery voltage) to the distributor coil?
You tested the ignition coil primary and secondary resistance and they were ok?
Sunday, June 15th, 2008 AT 6:51 AM
