landcruiser oil dripping to carpet
TOYOTA LANDCRUISER
HTUNGA
Toyota landcruiser VX 2002 4.2 turbo diesel at 102000km.
What may be the cause of clear oil dripping to the carpet of the front passenger through the cables under the gloves box?
Feb 18, 2007 at 5:37 AM
CHEVY22
  • 1,375 POSTS
sounds like it may be coolant , does it feel greasy??if it is coolant the heater core has failed , check that and reply please
thanks
Feb 18, 2007 at 9:24 AM
HTUNGA
Thanks for your answer Jim.
The dripping material is just like grease. Can this be coolant?
I had my car checked at the Toyota service for this problem, but they could not find any major cause and explained that the problem is caused by the melting of the wax around the cables, which sounded me nonsense.
I am not a professional, how can I check the heater core?
Huseyin
Feb 19, 2007 at 6:44 AM
CHEVY22
  • 1,375 POSTS
for the life of me i cant picture grease anywher but anything is possible , as far as the coolant pressure test you can buy a setup or have someone do it for you , usual charge around here is anywhere from 15 -40 bucks, the heater core is in that area that you stated
thanks
Feb 19, 2007 at 7:28 AM
HTUNGA
if it is the coolant shouldn't the coolant level in the radiator go down? and is the coolant that much greasy?
thanks
Feb 19, 2007 at 8:04 AM
CHEVY22
  • 1,375 POSTS
a small leak you would not see any loss in the radiator and yes coolant is greasy but not black in color
thanks
Feb 19, 2007 at 8:16 AM
HTUNGA
its just clear colorless grease not dark but looks too concentrated to be coolant but If you can not figure out any other reason I'll tell your suggestion to the toyota service and have it checked once more.
thanks
Feb 19, 2007 at 8:42 AM
CHEVY22
  • 1,375 POSTS
no i cant think of anything else , its a start anyway , hope i helped
good luck , if you do find it let me know
thanks
Feb 19, 2007 at 8:46 AM
