2004 Toyota Highlander cabin air filter
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOYNISSAN
Where is the cabin filter located ?
May 3, 2009 at 4:56 AM
BROWNCAT
it's behind the glove box. open the glove box (and empty it) and squeeze together the 'pins' behind/under the glove box and then remove the screw attached to the line attached to the glove box so it will fall forward completely. the filter has a little handle and just pull it out. FYI the filter should be replaced every season (3 or 4 times a year)
Jul 23, 2009 at 5:26 AM
