2001 Toyota Echo Alternator Bearing Fix
TONY50HORTON
How do I remove the rear alternator bearing on my 2001 Toyota ECHO. It's a 70 Amp alt, the car has 160K miles.
May 3, 2006 at 2:51 PM
LOSONE
  • 1,616 POSTS
You don't; you replace the alternator. The material they use for the case is frangable and you will end up destroying the case.
May 4, 2006 at 9:43 AM
Suggested Repair
Do not remove the rear alternator bearing. Replace the alternator, because the case material is fragile and attempting the repair will likely destroy the case.
Conversation Summary
The owner of a 2001 Toyota Echo with 160,000 miles asked how to remove the rear bearing from a 70-amp alternator. The expert advised against removing the bearing and recommended replacing the alternator, since the fragile case material would likely be destroyed.
