unusual starting problem 1981 corolla ke70
RICHARDD
Hi, I have a 1981 ke70 corolla with the 4kc 1300cc motor. It has done 200,000km. I was driving today and the engine died. It was just like turning off the key. Every time I try to start it the engine fires and then immediatly dies. It will start but will not run even for a second. fuel is ok do ypu have any other ideas?? Thanks.
P.S. this is the Australian corolla if that makes any difference.
May 5, 2007 at 9:26 PM
  • 75,988 POSTS
Check your coil and distributor pick-up inside and its connections if its okay check the ignition switch in and out
May 6, 2007 at 7:57 AM
RICHARDD
problem was coil resistor. fixed it yesterday thanks.
May 7, 2007 at 10:03 AM
