2004 Toyota Corolla Steering Wheel Noise
RICANWHITEY87
i just bought a 2004 Toyota Corolla and it runs perfect by the way...but everytime i turn the steering wheel it sounds like there's a marble inside of my steering wheel....i dont know what to do....could i take the horn cover off myself or should i have someone look at it? PLEASE HELP!
Apr 8, 2007 at 5:44 PM
  • 75,988 POSTS
[quote:6508ca3bd5="ricanwhitey87"]i just bought a 2004 Toyota Corolla and it runs perfect by the way...but everytime i turn the steering wheel it sounds like there's a marble inside of my steering wheel....i dont know what to do....could i take the horn cover off myself or should i have someone look at it? PLEASE HELP![/quote:6508ca3bd5]
Don't even mess with the horn cover-you might accidentally trigger the air bag and get squash it happen to me while sitting on the driver side - while a buddy dinking around under the dash and holly molly it deployed didn't know what the heck happened its like a driveby shootout again don't.
You sure its not the CV boot or the joint itself on the axle.
You're begining to make think! clock spring
Air Bag Clock Spring:
The air bag clock spring is designed to rotate the connector for automotive airbags. The most important feature of this product is its compatibility with other products, with four times as many circuits using up to four flat cables.
Apr 8, 2007 at 11:26 PM
RICANWHITEY87
i'm positive its not the axle....i can sit there and turn my wheel and hear something rolling around in there....i still have to go back to the dealership....soo i'll have someone there look at it...THANKS A LOT!
i probably would have done something bad...hehe
Apr 9, 2007 at 12:53 PM
Suggested Repair
Do not remove the horn cover yourself because of airbag deployment risk. Have a technician inspect the steering wheel, especially the airbag clock spring, for a loose internal part causing the rolling noise.
Conversation Summary
The owner of a 2004 Toyota Corolla hears a marble-like rolling sound inside the steering wheel when turning and asked about removing the horn cover. The expert warned against touching the horn cover because of airbag risk, mentioned axle joints, and suggested the airbag clock spring. The owner ruled out the axle and planned to have the dealership inspect it.
