1999 Toyota Corolla Right Front Noise
CHOPO2
I own a 1999 Toyota Corolla with close to 90,000 miles on it. Lately I have notice that periodically I will hear and feel a shuttering noise coming from the right front end of the vehicle. Again, I notice this sometimes (not always) when I brake and even sometimes when the car is beginning to accelerate. A friend of mine will hear it coming from the right front end of the vehicle as he walks beside it when it is slowly moving forward or backward. About every third revolution of the wheel will he hear an audible noise coming from the general direction of the right front wheel only. Any idea what could be causing this problem?
Oct 10, 2006 at 9:26 AM
  • 75,988 POSTS
Have your F/R brake assembly check to include the wheel bearing.
Oct 12, 2006 at 10:05 PM
FRANCIS 180
  • 18 POSTS
g'day choppo stones can and will get caught up between the disk rotor and the metal guard. sometimes all you have to do to get rid of them is reverse for a while. otherwise just pull the front wheel off and check it out. good luck with it :D
Oct 13, 2006 at 8:39 AM
PGJON
Front wheel drive.. correct? Have the rt. c/v joint checked out.
Oct 17, 2006 at 4:07 AM
Suggested Repair
Have the right front brake assembly inspected, including the wheel bearing. Also check for a stone caught between the rotor and dust shield, and have the right CV joint checked if the noise continues.
Conversation Summary
A 1999 Toyota Corolla with about 90,000 miles has an intermittent right-front shudder and noise during braking and acceleration. A bystander hears a sound from the right front wheel about every third revolution. The expert advised checking the front brake assembly and wheel bearing. Other replies suggested a stone between the rotor and dust shield, or a worn right CV joint on this front-wheel-drive car.
