2000 Toyota Corolla Axle Thump
2000TOYOTACOROLLA
I have a problem with my right axle making noise on my 2000 Toyota Corolla. The noises are coming from the transmission side of the axle. I just put the car up on blocks and ran the engine, but only one axle turns, the left. When I drive it on the road it makes a horrible thumping noise coming from that area, and it's not the tires as I have had those balanced and they are fairly new. I replaced the left axle about a couple of months ago and not sure if this new problem is related. Any info or help will be greatly appreciated. The car has 150,000 miles on it. I am unable to make a donation at this time but will as soon as I can. I can send a video of the problem if that would help. Thanks.[img:bf6b3642f2]http://www.2carpros.com/forum/automotive_pictures/109556_its_the_cats_car_1.jpg[/img:bf6b3642f2]
Oct 21, 2007 at 8:42 AM
MERLIN2021
  • 17,250 POSTS
Randy, if the inboard, or tripod joint is bad you will get this symtom, or a tranny mount, check for up and down and side to side movement in both! It's normal for only 1 wheel to spin...if you hold that wheel the other will spin!
Oct 21, 2007 at 8:47 AM
2000TOYOTACOROLLA
Thank you Mr. Merlin for the quick and informative reply. i will check both items you mentioned.
Thanks Again!
Randy
Oct 21, 2007 at 4:40 PM
Suggested Repair
Inspect the right inboard tripod joint and the transmission mount for excessive up-and-down and side-to-side movement. One wheel spinning with the car raised is normal if the other wheel is held.
Conversation Summary
The owner of a 2000 Toyota Corolla with 150,000 miles reports ticking and thumping from the transmission side of the right axle. Only the left axle turns when the car is raised and running, and the left axle was replaced a couple of months earlier. The expert says a bad inboard tripod joint or transmission mount can cause the noise and advises checking both for movement. One wheel spinning is normal if the other is held. The owner plans to check both items.
