1990 Toyota Corolla Drive Axle Stuck
MILLS FANNIN
I have a 1990 Toyota corolla with automatic transmission, 1.6 engine. and 130000 miles. I was trying to replace the driver's side drive axle. It came apart and did not snatch out as most axles do. I can not pry it out or bump it out with a hammer. I replaced the other side without incident
Jan 28, 2007 at 8:36 AM
  • 75,988 POSTS
[quote:cb23332e36="mills fannin"]I have a 1990 Toyota corolla with automatic transmission, 1.6 engine. and 130000 miles. I was trying to replace the driver's side drive axle. It came apart and did not snatch out as most axles do. I can not pry it out or bump it out with a hammer. I replaced the other side without incident[/quote:cb23332e36]
You probably need to dink around with the C-clip for it come out.
Jan 28, 2007 at 8:40 AM
Suggested Repair
Manipulate the transmission C-clip so the driver's side drive axle can release and come out.
Conversation Summary
The owner of a 1990 Toyota Corolla with an automatic transmission could not remove the driver's side drive axle after it came apart; prying and hammering did not free it, though the other side came out normally. The expert said the C-clip likely needs to be worked so the axle can come out.
