2002 Toyota Corolla Front Wheel Bearings Fix
BKLAHL
  • 5 POSTS
2002 toyota corolla I need to change my wheel bearings and I keep getting conflicting stories on what to change.
1st how do I remove the wheel hub
2nd do I need to replace the hub and the bearings or can I just replace the bearings and keep the old hubs.
3rd what special tools would i need to change the bearings.
thanks in advance
Bill
Feb 3, 2007 at 6:38 AM
LOSONE
  • 1,616 POSTS
The front hubs have pressed in bearing and do need special tools to remove the hubs and replace the bearing. This is a job for a certified mechanic.
Good Luck
losone
Feb 5, 2007 at 3:53 AM
Suggested Repair
Have a certified mechanic replace the pressed-in front wheel bearings. Special tools are required to remove the hubs and replace the bearings, so this is not a typical DIY job.
Conversation Summary
The owner of a 2002 Toyota Corolla asked how to remove the front wheel hubs, whether the hubs must be replaced with the bearings, and which special tools are needed. The expert replied that the front hubs have pressed-in bearings and that special tools are required to remove the hubs and replace the bearings, recommending a certified mechanic.
