1998 Toyota Corolla Inner CV Axle Removal
ESTUARDO
Toyota, Corolla, 1998, 100,000 How do you remove the inner end of cv axle?
Mar 26, 2006 at 5:57 AM
SQM
  • 6,383 POSTS
After removal of the hub and other components the CV axle will come out at you pull on it. Sometimes you will have to use a pry bar to slowly work it out.
Here is a helpful guide:
https://www.2carpros.com/articles/replace-cv-axle
I have attached diagrams of replacement procedure for your reference.
Jan 14, 2022 at 6:00 AM
Suggested Repair
After the hub and related components are removed, pull the CV axle out. If it does not release, carefully work it free with a pry bar.
Conversation Summary
The owner of a 1998 Toyota Corolla with 100,000 miles asked how to remove the inner end of the CV axle. The expert said that once the hub and other components are removed, the axle should pull out, and a pry bar may be needed to slowly work it free. A replacement guide and diagrams were referenced.
