2004 Toyota Corolla High Pitched Noise
TRISH2041
i have a 2004 toyota corolla with about 48,000 miles. my car makes a loud high pitched noise as soon as i turn it on and it doesn't go away. i had this problem a few months ago but not as bad and thought it might be the belt but had it checked and they said the belt was fine. so what could be the reason for the noise
Nov 30, 2006 at 4:06 AM
  • 55,694 POSTS
sorry, a loud squeeling noise is heard while the key is on and the engine is running, remove the drive belt and start the engine and see if it is still there.
Nov 30, 2006 at 7:15 AM
TRISH2041
the noise is coming from the engine i would know if it was the brakes
Nov 30, 2006 at 7:32 AM
  • 55,694 POSTS
:shock:
Nov 30, 2006 at 8:29 AM
Suggested Repair
Remove the drive belt and start the engine to see if the high-pitched squeal remains. If it stops, inspect the belt and accessory components; if it continues, the noise is likely coming from the engine itself.
Conversation Summary
The owner of a 2004 Toyota Corolla with about 48,000 miles reports a loud high-pitched noise as soon as the engine starts that does not go away. A previous check found the belt fine. The expert advises removing the drive belt and restarting to see whether the squeal remains. The owner says the noise is from the engine, not the brakes, and no further diagnosis was given.
