2000 Toyota Corolla Pulls When Accelerating
BUDDCHIEFER
2000 Corolla VE 50,000 FWD 4-cyl.
When I changed the bearings (passenger side front) I damaged the ball joint boot. Instead of replacing the entire piece, I put a new boot around the old joint. I squeezed the lubricant out of a new one and put it around the old one. It was hard work but I managed to get a new boot around an older ball joint. :twisted: I know that it has been contaminated and should be replaced soon, but does the boot hold a pressure along with protecting the joint from debris?
Would this cause my car to pull when I accelerate moderately? I have read about torque steer, but it didnt drive this way before I replaced the bearings. I went through Napa to have them pressed, and I dont think that I damaged the Tranny or CV axle end when I removed/replaced CV axle. :arrow: Pulls to left when I accelerate and back right again when I let off.
Jan 31, 2007 at 4:22 PM
  • 75,988 POSTS
[quote:846bd63236="BuddChiefer"]2000 Corolla VE 50,000 FWD 4-cyl.
Would this cause my car to pull when I accelerate moderately? I have read about torque steer, but it didnt drive this way before I replaced the bearings. I went through Napa to have them pressed, and I dont think that I damaged the Tranny or CV axle end when I removed/replaced CV axle. :arrow: Pulls to left when I accelerate and back right again when I let off.[/quote:846bd63236]
Better check that part of the suspension-something is wrong-by any chance did you overtighten the wheel bearings-there's such thing as preloading it.
Jan 31, 2007 at 9:15 PM
BUDDCHIEFER
Are you referring to the nut at then end of the CV axle? The bearing and hub assembly was pressed together by Napa.
Feb 9, 2007 at 1:44 PM
  • 75,988 POSTS
[quote:57e1bba3ca="BuddChiefer"]Are you referring to the nut at then end of the CV axle? The bearing and hub assembly was pressed together by Napa.[/quote:57e1bba3ca]
Yeap! Better have the Toe/Camber check-you probably misalign the knuckle and the struts.
Get a wheel alignment
Feb 9, 2007 at 4:16 PM
Suggested Repair
Check the CV axle nut torque and wheel-bearing preload, inspect the suspension including the reused ball joint, and get a wheel alignment to correct possible knuckle and strut misalignment affecting toe and camber.
Conversation Summary
A 2000 Toyota Corolla began pulling left under moderate acceleration and returning right when the throttle was released after the passenger-side front wheel bearing was replaced. The owner had damaged the ball joint boot, installed a new boot and grease on the old joint, and asked whether the boot holds pressure and whether contamination could cause the pull. The expert advised checking the suspension and possible overtightening or preload of the wheel bearing at the CV axle nut, then recommended a toe and camber check and wheel alignment because the knuckle and strut may have been misaligned.
