cannot see a circlip and the cv joint dosnt chap off.starting to annoy me.help please.chris
Aug 15, 2010 at 7:31 AM
✓Experienced Mechanic
Hi there,
There should be a "C" clip on the shaft end that fits into the transmission only, it is a wire "C" clip and with out it the axle will not lock in, your local drive line shop should be able to supply missing clips.
mark (mhpautos)
P.S. I have seen shafts break at the "C" clip groove, if there is no groove this will be the problem.
Aug 15, 2010 at 11:36 PM
