I can't get a flat rear tire off of my 1998 toyota corolla...is it rusted on or is there a trick? I took of the hub cap and lug nuts.
Sep 13, 2007 at 12:24 PM
Loosely reinstall one lug nut so the wheel cannot fly off. From a stable position, strike the back of the tire with a 5 lb hammer, rotate it halfway, and repeat about a dozen times. If it remains stuck, strike the outer edge of the rim the same way.
The owner of a 1998 Toyota Corolla could not remove a flat rear tire after taking off the hubcap and lug nuts and asked whether it was rusted on. The expert advised reinstalling one lug nut for safety, then striking the tire from behind with a 5 lb hammer and rotating it repeatedly; if needed, strike the outer rim edge.
