Battery checks good, posts are clean and tight but when starting the starter only clicks. There is 120k on the engine, auto trans..
Aug 21, 2007 at 3:20 PM
Jump-start the car to rule out a weak battery even if it reads about 11.5–12 volts. If it still only clicks, inspect the starter connections and consider a starter with a dead spot or worn brushes.
The owner of a 1996 Toyota Corolla with an automatic transmission says the starter only clicks even though the battery tests good and the posts are clean and tight. The expert notes a battery can still be weak at 11.5–12 volts and recommends a jump start. If clicking continues, starter connections, a dead spot, or bad brushes are possible causes.
