2004 Toyota Corolla suddenly does not work
67,000 MILES • 4 CYL • FWD • AUTOMATIC
MZLIU
A/C suddenly does not work. A/C press-burton light is on. Fuse is ok. compressor is idle and push in with running belt. no electricity signal to compressor. What's wrong?
Thanks
Jul 10, 2008 at 2:24 PM
KHLOW2008
  • 41,812 POSTS
Hi mzliu,
Check for power supply to compressor magnetic clutch relay.
Jul 12, 2008 at 9:23 AM
MZLIU
Thanks. no power. fuse is OK. Relay?
Jul 12, 2008 at 2:59 PM
KHLOW2008
  • 41,812 POSTS
Hi mzliu,
I mean power to relay, not from relay to compressor.
Pull out relay and test the terminals for power source, there should be 2 with engine running and AC turned on.
If only 1 powered terminal, check for blown fuse underhood if is the power supply.
Check wire and connection from ignition switch or fuse if it is the coil that is not getting power.
If there are 2 powered terminals, plug relay in and if it clicks and still no power to compressor, the relay is bad.
If it does not click, you need to check for bad ground, I don't have the schematic so unable to tell you where it would lead to.
Jul 12, 2008 at 4:38 PM
