No, that should be OK for now, I think it is time for a mechanic to take a look at the electrics, if you have no power at the comp, and the refrigerant level is OK, this will need deeper investigations, have you located the dryer yet, it is round and should be near the condenser at the front of the car, it will or should have a switch mounted on the top, this is the low pressure cut out switch, bridge it out and see if that kicks in the comp.
Mark (mhpautos)
Saturday, February 13th, 2010 AT 3:41 PM
