2004 Toyota Corolla Engine Noise after 20mph
120,000 MILES • 4 CYL • FWD • AUTOMATIC
TINA84
Hi! I can't seem to figure out what's wrong with my car. After I hit around 20mph, the engine gets really loud. I was worried it might be my transmission, but the shifting is doing so as it normally would. I can almost feel the noise while driving. Any idea what this could be? I just recently had a driving belt replace and my transmission fluid changed and it seemed to run better, but the noise/vibration is still there. The more acceleration there is, the louder/worse it gets. I scares me, because it sounds like it's going to explode! Help?!?!
Aug 16, 2010 at 4:15 AM
MMPRINCE4000
  • 8,548 POSTS
Check the oil level and transmission fluid level, check trans fluid with engine running.
What kind of noise does it make? rattle, klunk, screech?
Aug 17, 2010 at 2:33 AM
TINA84
It just sounds like the engine is working way harder than it needs to be. It's really loud! Not a very specific kind of noise, I know. But It just sounds like I'm slamming the pedal to the metal, and I'm not. :/
Aug 17, 2010 at 8:08 AM
MMPRINCE4000
  • 8,548 POSTS
It may be as simple as an exhaust leak, I would have it checked for that to start,
Aug 18, 2010 at 12:40 AM
