You are welcome.
If the car sits in garage for more than a month, gasoline will deteriorate and break down causing varnish to form. This can cause many problems.
SeaFoam or fuel stabilizers (such as Stabil) will counteract this problem, keeping gas fresh for over a year.
The loose plug will cause problems, replace and use anti-sieze (small dab of it) on plug threads to prevent galling, also use dielectric grease on plug wire connections, this will seal plug and keep moisture out of plugs. Torque plugs to proper ft. Lbs. And again use Denso or NGK iridium plugs on this engine.
Sunday, August 30th, 2009 AT 8:18 AM
