Since the shaking got worse after the tune up, I would replace the plugs with factory plugs and wires (Denso, NGK).
The ticking could be a valve shim, these require special tools and would best be done by Toyota or reputable garage.
The wrong plugs, or loose plugs can cause a lot of problems.
SPONSORED LINKS
Friday, October 24th, 2008 AT 8:45 AM
