2006 Toyota Corolla Engine vibrates or shakes on neutral po
2006 TOYOTA COROLLA
46,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICHARD_BD
I bought a used Toyota corolla 3 months back. On test drive i found the 1NZ-FE engines shakes a bit in neutral gear. Then the seller told me that the spark plugs probably warn out which he replaced and the engine shaking problem was gone.
After 3 months i m again experiencing similar shaking or vibration of engine on neutral position.
Should I just replace the spark plugs or check other parts for this problem?
What type of spark plugs are suitable for my car?
I ran only 2,500 km after i bought it. The car runs on both octane and natural gas. So far the car is running well.
I would appreciate a reply from u with the solution.
Oct 3, 2009 at 10:23 PM
MMPRINCE4000
  • 8,548 POSTS
If it is a misfire, you should be getting a check engine light?
Use only Denso plugs and make sure that the crush washer is flat on the plug, they can sometimes get "cocked" and cause this problem.
But I would check codes and if a misfire, I would change plugs and again use only the Denso, Toyota suggests.
Oct 4, 2009 at 1:47 AM
RICHARD_BD
Thanks for the suggestion. I will check it and update u accordingly.
Oct 4, 2009 at 7:59 PM
MMPRINCE4000
  • 8,548 POSTS
Your welcome, I am curious, what state/country are you from? The 1NZFE engine is mostly used in the Yaris.
Oct 5, 2009 at 2:11 AM
