2003 Toyota Corolla Engine needs to be accelerated until ca
JUNIOR913
  • 2003 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 92,000 MILES
My 2003 corolla has to be warmed for 10minutes before I can use it. If I take my foot off the accelerator it will turn of and give me a rough time to start up again. Once the car reaches normal temperature it wont turn off, but the idle speed remainns a bit low. I have replaced the spark plugs, coils, timing chain, coolant sensor and oxigen sensor. I have read the code it gives and it always says "missfire cylinder 1, 2, 3, 4" I have asked over a dozen mecanics and no one knows what is wrong with the car
Wednesday, September 29th, 2010 AT 9:42 PM
MMPRINCE4000
  • 8,548 POSTS
If you are using the correct plug and wires. I would suspect the CAT. If clogged or partially clogged it will cause misfires.
Misfires can cause it to overheat and melt the ceramic material inside, causing excessive backpressure.
Perform a backpressure test on CAT.
Friday, October 1st, 2010 AT 7:00 AM
