Anytime you add non factory electrical equipment, you run the risk of overloading the system.
Depends on amp draw, wattage.
The power steering problem, I would check level and hose connections.
Coolant problem is probably a leak.
SPONSORED LINKS
Wednesday, September 29th, 2010 AT 8:31 AM
