2001 Toyota Corolla water pump
2001 TOYOTA COROLLA
81,000 MILES • 4 CYL • FWD • MANUAL
ADZE
although my car is driving fine and there is no problem with my waterpump, i was wondering if there is anyone who might know what the average life of a water pump, especially for my car. also, when a water pump starts to go, does it go all at once, or is there usually some advance warning signs such as water leaking before it totally craps out.
Mar 10, 2008 at 11:22 AM
MMPRINCE4000
  • 8,548 POSTS
The water pump has a small "weep hole" that is visable from above. Coolant in the weep hole would indicate a bad seal or bearing and the pump would need to be replaced.
As far as longevity, I have had the original water pump in two Toyota's for almost 15 years.
Jul 27, 2020 at 9:51 AM
