No visual coolant circulation,
Could be the water pump itself-One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad.
SPONSORED LINKS
Monday, July 27th, 2020 AT 4:44 PM
