2001 Toyota Corolla oil burning
200NAGLE
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 73,000 MILES
What could be the cause of excess oil burning.I dont see any leaks or smell any fumes.I know spark plugs have not been changed since 27,000 --when I purchased the car.I was told on last oil change by toyota
that special plugs were in car & plugs were due to be changed at 75,000 miles.
What other areas on the car could be fault to oil burning.
yours 200nagle
Friday, January 30th, 2009 AT 5:47 PM
  • 31,937 POSTS
HI there,
The main causes for excessive oil consumption is wrong oil diluted oil, faulty rings and worn valve guides & stem seals, get a leak down test done to check the rings first, start here.
Mark (mhpautos)
Friday, January 30th, 2009 AT 6:10 PM
