Engine oil shortage uses oil
199,000 MILES • 1.8L • 2WD • AUTOMATIC
ADEHINLE
My car Toyota corolla 2001. Always have engine oil shortages. No any leakages under the engine. If i do the servicing after a week the gauge of the oil would have reduced. No leakage. I always top up my engine oil every one one week. So that it will be at the normal gauge.
Mar 1, 2014 at 5:32 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
it sounds like the motor is using oil and its got high mileage. if the oil in the motor is very dark you might benefit from an oil flush to remove sludge from the oil system in the engine. if its not, then check the air filter. if its dirty and restricts too much air it causes the engine to use more air form the crankcase taking up excessive oil vapor with it
Mar 1, 2014 at 6:47 PM
REMYJEREMY
I have to do the same every week I drive on the highway every day 50 miles a day rarely drive in the city I use my jeep for the city but back to the Toyota issue I work on my car myself not a mechanic but I recently did a oil flush and. Air filter change few months ago and keep up on the simple things to make the car run wonderful only issue is I lose oil every week don't know where because I never smell oil burning or any leaks on the ground since I've owned it and it's been losing oil since I bought it this year in February it's a i4 using 5w30 any solutions? Or possible theorys I'm always willing to work on my car to find out great at reading directions or a video helps to would love to fix this
Sep 7, 2014 at 1:08 AM
WAJIDU WAHAB
Oil is drying in engine and it is leaking from no where, what can I do to solve the problem
Mar 1, 2017 at 4:19 AM
MERC70
Engine Mechanical problem
2001 Toyota Corolla 4 cyl Front Wheel Drive Automatic 76000 miles
I have a 2001 corolla that I have only owned 2 months so I can't speak of it's history. It uses oil, quite a bit in fact. One trip of 150 highway miles burned 1 quart. A couple weeks later, a 500 mile trip burned 1 quart. During that last trip, the check engine light came on. No oil appears on the driveway and it doesn't appear to burn oil when we just go around town with it (though we might not drive hard enough to notice it).
Toyota dealer says it is the piston rings, but his diagnosis was not really based on many facts. He said it smokes, but I don't see that. He said he pulled the valve cover and everything looked ok so the only way out is for the oil to get past the rings. He want's $4k for an engine replacement.
I took it to somebody else and he said nothing is wrong with the car (I haven't gone back to him with the check engine light on). He said some oil burn is ok and suggested heavier oil (even though Toyota calls for 5w-30). I started topping the engine off with heavier oil just to see what would happen and that was during the 500 mile trip when the check engine light came on. May or may not be related to me using 10w-40.
I took it to yet another guy who I trust more and he did a compression test. The 4 cylinders are 138, 138, 150, 155. He said that is a problem and he looked up some stuff on the computer and said the corolla specs are 217 max and 145 min. He also checked the PCV valve which he pronounced ok by taking it off and shaking it. It rattled so he said it's ok. This guy also read the check engine problem - it's P0420. This means it's either the catalytic converter or O2 sensors. He's guessing the catalytic converter because I am sending oil down the tailpipe and the catalytic converter has burned itself up trying to burn that oil.
Looking for some help, some suggestions. How do the compression numbers sound?
Oct 9, 2017 at 3:11 AM (Merged)
  • 75,988 POSTS
I took it to yet another guy who I trust more and he did a compression test. The 4 cylinders are 138, 138, 150, 155. Is this the wet test? if so the compression is too low- Normal compression up to 218psi with 20% tolerance allowable-
MASTERTECHTIM
  • 4,750 POSTS
code 420 is cat low efficiency and is caused by a bad cat converter not o2 sensor problem. vehicle has low miles, another option is you have carbon build up on the pistons and valves and possibly piston rings. if you have a top engine clean done properly it will remove alll the carbon from the top end and quite possibly free up those sticking piston rings. just a suggestion and would be my next course of action.
MERC70
Thanks for the fast response.
rasmataz - I don't think it was a wet test. I didn't ask, but since the guy knew the story, I doubt he was trying to get high readings and pull one on me.
mastertechtim - re: 02 sensors. I got that from the diagnosis flow chart for the 420 code. It says check o2 sensor 1, then o2 sensor 2, and if they check out ok, replace cat converter.
re: sticking piston rings. Are you saying the compression could be low because there is build up causing the rings to stick and hence slow down the piston which would drop compression? Where is the oil going if the rings are sticking?
  • 75,988 POSTS
Get your mechanic to do a compression check both dry and wet and follow it with a cylinder leakdown test and comeback with the results. If you have a problem with the rings or cylinder wear it will leak right thru then get burned up in the combustion chamber- Valves guides/stems and seals anything is possible to leak inside the chamber-
DOWNSB
Oil burning is probably the most common issue in an 98-02 Corolla. Everything you're describing is some of the same issues I've had. I've got about 150k miles on my Corolla and haven't done much (as far as taken to mechanic) to do anything about this issue besides replace the cat when the CEL came on. I have used engine cleaning oil additives and they can do a bit to help clean up the engine but aren't a professional cleaning job. Piston rings is the most common answer for why this is happening, but I've heard other responses as well. If you're concerned with it then I'd take it to a mechanic but I can say that as long as this has been happening to me...I probably won't take it anywhere to have it cleaned anytime soon. Regardless, make sure you keep the oil levels within tolerance (3.7Q is what the engine is supposed to have in it apparently).
Here's the list of things I've tried:
-Wal-Mart Injector cleaners
-CD2
-Engine Flush
-heavier oil
-lighter oil
-full synthetics
-plain dinosaur oil
-Ceramizer
-CerMet
-Auto-RX (this is what I'm currently on)
Of all of them, the Ceramizer increased fuel economy and seemed to increase HP (look it up and you'll find it may help with your compression problem).
The Engine Flush seemed to do the most work in the least time (run for 5-10 minutes before you change oil at idle speed after adding the flush to your oil reservoir) but only made a difference for about 2 weeks after each change.
Full Synthetics helped to keep the engine quieter, while it also seemed to burn much more quickly.
Lighter oil seems to burn more but also seemed to keep the engine feeling slightly more peppy.
Heavier old didn't burn as quickly but made my car harder starting in the colder months.
CD-2 is an oil detergent and did seem to help a bit; I ran it in my car for about 3 weeks and then changed the oil (and found the oil DID come out very black and the oil filter WAS heavier than the control filter on my other '01 Corolla-indicating higher amounts of debris trapped) at ~1400 miles since last change (yes, changed it VERY early).
CerMet was snake oil and I wouldn't recommend (ounce per ounce it's about the same price as gold, or was when I bought it).
Injector cleaners didn't do a thing.
The Auto-RX has only been in my car for about a week now so it's too early to tell if I bought more snake oil or not.
And the plain dino oil? Why buy the expensive stuff if it's just gonna burn off anyway? =]
JUSTIN98
my 2001 corolla uses about 1.5-2 quarts of oil every 500 miles depending on how the engine is ran (interstate speeds vs. back roads). I do my own oil changes and noticed this around 60,000 miles. No visible leaks on engine and no smoke coming out of tailpipe (per friend who followed me) and no buildup on bumper near exaust pipe. The car runs great you just have to keep a close eye on the oil level. Just wondering if you had any idea where the magical oil may be escaping or any suggestions to check
TRIZI
I have the same issue ... I'd like to know how the Auto-RX worked out. Am also considering Valvoline Max Life Oil additive.
  • 75,988 POSTS
Its only two places it leaves the engine either its leaking or being burned in the combustion chamber.
Inspect your sparkplugs
DOWNSB
the Auto-Rx helped for a little while, but I think it also made things a little worse too. I noticed after I used it my engine seemed a little better, but now it's burning MORE oil than before, and I had spent the extra bucks for Royal Purple this time (you can understand why I'd be a little upset that my car burned this stuff up).
I'm getting ready to take the engine apart and replace the rings, pistons, maybe get it bored sleeved, and honed, replace the cylinder head, and new cams. When I do this in the next month or two I'm sure I'll probably get a chance to snap a few photos and see what it looks like is going on inside the engine.
BRIANADLER
I've been losing oil for about 2 years on my 2002 Corolla. I figured out it was happening after receiving this car as a gift at about 90K. I probably drove it more than 1k miles though before I knew I had an oil loss issue (dipstick was dry). I've been adding around 1 qt oil per tank of gas for over a year. I had started to use 10w40 and 20w50 to lessen the loss (which I now know was really dumb in terms of engine protection even though it worked). Last week the car crapped out (no compression on one cylinder and half on another) at 110K.
I took it in and the mechanic suggested replacing the engine with a used engine that they are able to get from Japan that had 29k on it. It was a hard decision but after doing some research (and suspecting there was a design flaw somewhere) I decided to have the work done ($3600 parts and labor).
But I kept doing research and finally figured out exactly what's going on. The piston on the left is the redesigned one. The piston on the right is the poorly designed one. Those four holes clog, the oil has no where to go but up and over and that's where the oil loss comes from.
The only things I have read that may have some benefit other than getting the better piston design are:
1. Sean Foam treatments on a regular basis might help. But I'm guessing only if you start early.
2. highway driving exacerbates it. That is my experience and that of lots of other people. Maybe it only occurs at higher rpms. I'm thinking about never driving over 60 when I get it back.
3. Changing the oil early. I'm probably going to do it every 3k now like clock work.
If I knew a week ago what I know now, I would sell the car for $1200 (I found a mechanic who wanted it). But I decided before getting all the facts to have the work done and even though they haven't finished, I'm committed. So I'll have a 29k engine on a 110K body and I'll do what I can to minimize the piston issue as much as I can.
DOWNSB
So does your new engine have a different cylinder head and rod set? Looks like the piston is longer and would be a danger to valves at the least...
Just wondering!
FRONIE99
2001 Toyota Corolla 4 cyl Automatic 96200 miles
I have to add 2/3 quarts of oil every two /four weeks, depending the amout of driving.
There is NO evidence of an oil leak and no black smoke at all when the car is in use. Any ideas?
BRIANADLER
That pic is nothing to do with my new engine. It's just a pic I found on another site that I thought was the old design and the new design. But it actually isn't. It's the old design and something else. The PDF is more useful.
The engine my mechanic is putting in has the same faulty pistons which is why I'm regretting having given the go ahead. But I didn't know what I now do and neither did my mechanic. This information should have been much better publicized considering how many Corollas are out there with this issue.
  • 31,937 POSTS
Hi there,
You will be burning oil in small quantities that will be hard to detect, if it is not leaking it is being burned, it can't go anywhere else. what grade of oil are you using and is it synth or mineral based?
Mark (mhpautos)
RD3000GT
2001 Toyota Corolla 4 cyl Two Wheel Drive Automatic 55000 miles
Noticed oil use when car was used for commuting to college (interstate driving). Dealer did oil comsumption test and determined engined needed new rings and valve seals. Did repair at 54K no oil use during first commute then start use again. When you run car around town it uses no oil and oil stays very clean. When car is used on highway it uses 1 qrt per 500-750 miles and oil gets dirtyed fast. Last trip to dealer they cleaned PCV and put in 20W50 and lucas oil. Car did not use around town but one trip to school (250 miles) used 1/2 qrt and oil got dirty. Obviously they don,t know whats wrong. I am looking for good ideas to present to them to fix this issue.
Thank You!!!!
MMPRINCE4000
  • 8,548 POSTS
Have them do a compression test for bad rings, if they replaced the rings and valve seals you should not be having this problem.
Using 20-50 oil and Lucas oil is a band-aid fix and the dealer should know better.
Have them re-ring the engine, check the valve seals and guides (seals for missing or distorted garter springs, guides for excessive clearence) and cylinder walls for scoring.
Also have them check the oil pump pressure relief valve and measure oil presure with a mechanical gauge.
How much did they charge you for this? Putting in new piston rings is a major repair. I am suprised they didn't just do a new shortblock.
These repairs should be done at their expense.
RD3000GT
Thank you mmprince4000. I will take it up with the dealer and request they take your reccommendations. I appreciate the sound advice.
RD3000GT
The cost for repair was $2400 but they covered half since the car only had 52K even though it was out of warranty time-wise.
RD3000GT
The Toyota dealership finally agreed to do a short block at no cost me! Thanks again for the great advice. The car run great now and even some seemingly unrelated problems have disappeared. It was a great Christmas Blessing!!
MMPRINCE4000
  • 8,548 POSTS
Glad to hear it, Happy new year....mmprince4000.
TIM EVANS
2001 Toyota Corolla with about 100,000 miles uses oil. Can't see any obviouse leaks. Had 2 Different mechanics look for leak. Could not find any checked compression and all cyliders were eaual. I need to add oil every couple of hundred miles. What could this be ? Would it be wiser to trade it on something else or pay for repairs. I still owe about $3800 on it.thanks
LEGITIMATE007
  • 5,121 POSTS
do you have any noticeable smoke coming out of the exhaust
MARIOC68
  • 120 POSTS
Hey there
My car, a 1995 Toyota Corolla engine 5A-FE engine is consuming too much oil. Note that not expelling white smoke. Not I find a major leak.
Use 15W40 multigrade oil. I see q traveling approximately 2,000 kilometers the engine has already consumed as 1 liter approx.
JOHNNYT73
  • 924 POSTS
Replace your PCV valve. Decarb your intake system. Try those and see if that helps.
MARIOC68
  • 120 POSTS
thanks for answering, the PCV is new; to decarbonise the intake system Seafoam I can use?
  • 31,937 POSTS
Do a leak down test or a wet and dry comp test to see what condition the rings are in, if there is no external leaks it must be going out the exhaust. Any oil burning will show light blue smoke on start up and on deceleration in the early stages of ring wear.
FUTBOL056
own a toyota corolla 2000-standard 200k mile- and uses alot of high mile oil. i change oil every 2 month but is run very well. what can i do to stop puting oil so often.
thanks
  • 75,988 POSTS
If its not leaking externally-have the engine compression checked-could be valves/rings/cylinder wear-
FUTBOL056
thank you so much but what about my wife altima 2003 she really need that car. thank again
RONALDBROWN
2002 Toyota Corolla 4 cyl Front Wheel Drive Manual 21000 miles
Fully synthetic oil has been used every year up to now, but I am thinking of changing to semi synthetic, do you think this could be detrimental and would it still last a year doing 3 to 4000 miles
Oct 9, 2017 at 3:12 AM (Merged)
MMPRINCE4000
  • 8,548 POSTS
No it should not hurt anything. Change the oil and filter every 3-4K and you will be fine.
MHAYYAD
  • 35 POSTS
I usually use oil 3000 km
When consumed all these miles on the highway speed between 90 to 120 km per hour
Can I use the oil more than 3000 kilometers, or replace it within the time limit specified
Nov 21, 2019 at 10:18 AM (Merged)
  • 75,988 POSTS
Change the filter and oil every 2,500 miles
MHAYYAD
  • 35 POSTS
This means that the oil will be borne by 1000 kilometers further
But factory recommend that I change my filter every 10000 K.M
Why do I change it to 4000 km
2500 mile= 4000K.M
regards
FORDRACING24
  • 65 POSTS
Toyota recommends an oil change/tire rotation every 5,000 miles. You can do it sooner than that if you wish to around every 3,000 miles.
