2001 Toyota Corolla Leaking Anti-Freeze
2001 TOYOTA COROLLA
ERINMARIE312
2001 Toyota Corolla 120000 miles
Our 2001 Toyota Corolla Sport is leaking anti-freeze or collant (greenish neon color) into the inside of the car on the passenger side under the glove-box, but only when parked uphill. Recently the car over-heated while driving uphill. Is this serious? And is it the anti-freeze? Can I fix this myself or is this a cheap fix?
Apr 12, 2009 at 6:54 PM
  • 31,937 POSTS
Hi there, this is sounding like a heater core leaking, you will have to get the cooling system pressure tested to tset and confirm this first, if so i would be getting a mechanic as it is a fairly major job, approx 7 hours.
mark (mhpautos)
Apr 12, 2009 at 10:18 PM
MMPRINCE4000
  • 8,548 POSTS
Mark is absolutely correct, but I would have to ask you a question,
Have you ever had the cooling system flushed and coolant changed? Toyota uses an antifreeze called "Toyota Red", it is the only antifreeze I would use in the 1ZZFE engine.
Apr 13, 2009 at 1:40 AM
ERINMARIE312
We got it from his mother so I am not sure but we will ask. I just called the toyota maintenance center and planning on bringing it in.
Apr 13, 2009 at 8:45 AM
