2001 Toyota Corolla
MYLESE
  • 2001 TOYOTA COROLLA
Brakes problem
2001 Toyota Corolla Two Wheel Drive
I JUST FINISH WATCHING YOUR VIDEO ON HOW TO REPLACE BRAKES AND ROTOR. IS THAT FOR ALL MODELS? AND IS REALLY THAT EASY?
Wednesday, July 2nd, 2008 AT 6:11 PM
MMPRINCE4000
  • 8,548 POSTS
Toyotas are very simple to change. Raise front, put on jackstands.
Remove wheel, two bolts hold caliper, remove and hang (support) out of way. Remove bracket, replace pads, replace rotor, install bracket, install caliper.
One thing you will have to do is to use a C-clamp to push the caliper piston all the way in to accommodate the new pads.
Thursday, July 3rd, 2008 AT 8:35 AM
MYLESE
Thank you very much for your reply. Sound easy enough, I guess I'll make my way to KRAGEN and pick up some supplies.
Thursday, July 3rd, 2008 AT 10:46 AM
