Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Brakes
Rotor
Replace/Remove
1990 Toyota Corolla Ignition Rotor
1990 TOYOTA COROLLA
252,000 MILES • 4 CYL • FWD • MANUAL
BENNYL
MEMBER
1 POST
How is the ignition rotor removed to be replaced? And how is the new one to be put on?
May 13, 2010 at 11:22 PM
Experienced Mechanic
Hi there,
un clip the distributor cap, and the rotor will pull off, it will only fit on one way as will the distributor cap.
mark (mhpautos)
May 14, 2010 at 12:10 AM
MMPRINCE4000
As Mark says it pulls straight out, replace with Toyota part, as aftermarket rotors are not very good.
May 14, 2010 at 12:57 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
