I would probably seek another opinion, struts generally need to be replaced when the seals begin leaking fluid.
Somewhat worn, doesn't say much.
I would have the front suspension checked, ball joints, tie rods, bearings, brakes and bushings for excessive play, if everything checks and the alignment is correct rotate the front tires to rear and see if it helps.
SPONSORED LINKS
Thursday, July 24th, 2008 AT 4:20 AM
