My fuel pump was going out so I had it replaced. Then it wouldn't start so we changed spark plugs. And NO luck so we changed Fuel filter and still NO luck! The fuel pump is running and the injectors are working but the car still isn't running! We can get it started if we pour gas into the air filter and if I slowly press the gas pedal the engine revs up but if I try to give it too much gas at one time the engine dies out and won't restart! The car was running before we changed pump so I don't think it is anything major but any help would be greatly appreciated!
Thanks So Much
SPONSORED LINKS
Wednesday, July 15th, 2009 AT 7:26 AM
