2000 Toyota Corolla ignition switch?
SAMSAM
  • 2000 TOYOTA COROLLA
  • 4 CYL
  • 71,000 MILES
Please help, I have a toyota corrolla 2000 gs, when I turn the key normally the car will not start.I have to apply a strong upward motion and turn the key at the same time then the car will start. Is the ignition switch faulty. Thank you
Wednesday, May 14th, 2008 AT 4:03 PM
MMPRINCE4000
  • 8,548 POSTS
Sounds like the ignition switch or the wiring to it. I would take it to a good locksmith and have it checked. You can buy replacement switches, but then the ignition key would only work in the ignition.
If the locksmith has to replace the switch he can key it to work with the original key.
You can also call Toyota and ask for prices, but a locksmith is usually less expensive (in my experience).
Friday, May 16th, 2008 AT 5:23 AM
