2001 Toyota Corolla IGNATION KEY
JOMON1973
  • 2001 TOYOTA COROLLA
  • V12
  • MANUAL
  • 51,000 MILES
HI I HAVE A PROBLEM WITH MY KEY BUTTON LOCK AND UNLOCK BUTTION ARE BROBEN HOW CAN I GET KEY CASE AND BUTTION THANKYU
Sunday, January 31st, 2010 AT 1:21 AM
BMRFIXIT
  • 19,053 POSTS
Disconnect and shield negative battery cable.
Remove steering wheel.
Remove upper and lower steering column covers.
Remove combination switch (if necessary).
Disconnect ignition switch harness connectors. If shear bolt studs are accessible, use a hacksaw to cut slots into exposed studs. Using a screwdriver, remove studs.
If shear bolt studs are recessed or hard to reach with a hacksaw, center punch studs.
Using a drill bit and screw extractor, remove studs.
Remove ignition switch, column upper bracket and lock cylinder.
To remove lock cylinder from column upper bracket, place ignition key to ACC position. Using a screwdriver, push down on stop pin located on side of column upper bracket. Pull out lock cylinder.
Sunday, January 31st, 2010 AT 7:00 AM
