2000 Toyota Corolla Car suddenly slowing down
MVMANOHAR
  • 2000 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 80,000 MILES
Recently I bought a second hand car - Toyota Corolla 2000 LE. When I stop at signal and accelerates when it is green, it moves slowly though I give more acceleration than normal. It used to happen once in a while and I'm living with it.
Today, in traffic, when I'm climbing a small hill, it slowed down almost full when I was at 30mph. Fortunately, I managed to go top of that hill and got down and drove 2 miles to reach home without any problem though I stopped at signals. This is the first time that happened to me at 30mph.
Please suggest me how could I fix this problem. Am I unlucky having this car?
Monday, March 23rd, 2009 AT 7:59 PM
MMPRINCE4000
  • 8,548 POSTS
Have fuel pressure checked with mechanical gauge. Inspect air filter for build up of dirt.
Tuesday, March 24th, 2009 AT 5:50 AM
WADE4698
If the temp guage is creeping up I would suggest that the catalytic converter is somewhat plugged.
Tuesday, March 24th, 2009 AT 10:24 PM
MMPRINCE4000
  • 8,548 POSTS
It is possible the convertor is clogged. Usually a clogged convertor will cause backfiring, and may run better cold than hot, but it is possible.
Wednesday, March 25th, 2009 AT 6:36 AM
MVMANOHAR
  • 6 POSTS
My car's temperature gauge is always slightly below to middle even in a long drive.
Yesterday, I checked air filter and it is looking white. I don't see any dust on it.
I think I may have to get fuel pressure checked.
Before I get it checked, I will take OBD codes from 'Advance auto parts' shop and will let you know.
Thanks a lot for trying to help me.
Wednesday, March 25th, 2009 AT 10:55 AM
MVMANOHAR
  • 6 POSTS
I just got it checked for Error codes. I inserted the machine into the OBD while ignition is ON and engine is not running. Please go throug below codes and let me know if I can try anything:
Error Codes: 2
P0133
O2 Sensor circuit slow response (Bank 1 Sensor 1)
P0133 Pending
I/M Monitors:
Misfire monitor > OK
Fuel system Monitor > OK
Comp Component > OK
Catalyst Monitor > OK
HTD Catalyst > N/A
Evap System monitor > OK
Second air system > N/A
A/C refering monitor > N/A
Oxygen sensor monitor > OK
Oxygent sensor heater > OK
Egr system monitor > N/A
View Freeze frames:
DTC that caused freeze frame > P0133
Engine RPM > 612 rpm
Load value > 20.0%
Coolant temp > 186 Deg FAH
Intake air temp > 53 Deg FAH
Short term fuel trim1 > 0 %
Long term fuel trim1 > 16.4 %
Short term fuel trim3 > -100.6 %
Long term fuel trim3 > - 100.6 %
Vehicle speed > 0 mph
Fuel system 1 > clsd1
Fuel system 2 > N/A
Wednesday, March 25th, 2009 AT 2:15 PM
MMPRINCE4000
  • 8,548 POSTS
The upstream O2 sensor should be replaced, upstream sensor is before the convertor.
Thursday, March 26th, 2009 AT 7:20 AM
MVMANOHAR
  • 6 POSTS
Yesterday, when I went for 25miles drive. Suddenly, engine light popped up. So, I checked error codes again. I erased codes and checked again and the output is as follows:
Error Codes:
None
I/M Monitors:
Comp Component > OK
HTD Catalyst > N/A
Evap System monitor > Inc
Oxygen sensor monitor > Inc
Oxygent sensor heater > Inc
View Freeze frames:
None
What is INC?
After erasing codes, I didn't see any codes. I tried 3 to 4 times but I didn't get any error. Also, engine light is turned off.
Do you think that there is no problem with my car, now?
Thursday, March 26th, 2009 AT 1:39 PM
MMPRINCE4000
  • 8,548 POSTS
If car is performing normally, then just monitor the ckeck engine light, if it comes on again, have codes read and see what they say.
Saturday, March 28th, 2009 AT 9:34 AM
MVMANOHAR
  • 6 POSTS
Yeah. Sure. I will let you know if I find any error codes again.
Thanks to all for your help.
Sunday, March 29th, 2009 AT 11:53 AM
MMPRINCE4000
  • 8,548 POSTS
This entire episode may be a simple as a tank of bad gas, but keep an eye on it.
Monday, March 30th, 2009 AT 8:27 AM
MVMANOHAR
  • 6 POSTS
Is it? Everytime, I'm filling up gas at 7Eleven which is near to my home. I used to smell the smoke something different. Also, I used to get less MPG which is less than 24MPG which is not usual for Corolla. I should get at least 28MPG in city and 32MPG on highways.
For the first time, I went to "EXXON mobil" to fill gas tank.
I felt that car is going smooth than before. I don't know whether it is because of resetting codes or good gas.
Let me check MPG this time and will let you know.
Monday, March 30th, 2009 AT 10:13 AM
