You will have to raise the car, remove the stone guards, and inspect the underside of the vehicle.
Look for any debris jammed in the pulley system, and bent components like the oil pan or transmission pan.
Also inspect the CAT. They can be damaged by an impact event, Which will cause the CAT to become clogged and severely reduce performance.
SPONSORED LINKS
Wednesday, October 1st, 2008 AT 9:16 AM
