Trouble starting the engine?
  • 31,937 POSTS
Coolant temp sensor, fuel pressure, clean throttle body and idle control, check for vacuum leaks, scan for any unresolved fault codes, general tune, check all these first.
Friday, October 16th, 2020 AT 10:10 AM (Merged)
ED.J.MURPHY
  • 1995 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 120,000 MILES
When trying to start the car it will click but not turnover. After a few trys it will turn over and start fine.
MMPRINCE4000
  • 8,548 POSTS
Check starter and battery connections.
If problem persists, remove starter and have it bench tested at most autoparts stores.
I have seen the Denso starter develop "dead spots" where it will do what you describe. Only fix is to replace it.
