Is there an impact on oil if we use the car on the highway or within the city?
And if you usually use oil 3000 km.
Within the city when should I change him?
If you and I will use on the highway when should I change him?
regards
SPONSORED LINKS
Tuesday, June 15th, 2010 AT 3:42 AM
MECHANIC
Hi there,
There is no difference between the oil you can use for city or county driving and as long as you change the oil on a regular basis, 3,000Mls or 5,000KM's this is all you need to do to maintain good engine lubrication, don't forget the filter as well at each oil change.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, June 15th, 2010 AT 5:35 AM
MHAYYAD
MEMBER
Mark
but change oil filter every oil change it is not like factory recommend every (10,000 K.M genuine part)
as per the Car manual. Why you till me every 5,000K.M?
OR
use (Mobile One oil)it used for 10,000 K.M and change the oil filter with the oil change every 10,000K.M
please use K.M with your answer not mile to keep me away from the confused :)
regards
Tuesday, June 15th, 2010 AT 5:56 AM
MECHANIC
You can run 10,000Kms, if you wish, I do mine every 5,000Km and a filter change, it's just a personal preference, many of my customers do as I do as well, but as I said 10K is fine it's up to you.
