Excessive oil usage
MYKOLA
  • TOYOTA COROLLA
Toyota Corolla VE 1999, 119K mi
The last time I measured oil usage, it was about a quart of oil per 250 miles. Showed it to auto mechanics (twice, so far). They changed PCV valve (just in case, saying this is the most common cause) and checked everything thoroughly. There are no oil leaks, no noticeble oil burning or anything that could give a clue for where the oil goes. They performed some tests (I did not get what exactly they did, sorry), and were not able to detect any problem. So, I do not know what to do now, after they gave up. Does it make any sense to try and find the problem on my own (then, what to look for?)? Or should I seek an expert advice? (And from whom? It is such a waste of time to have it checked over and over again and find nothing.). Thank you.
Saturday, July 21st, 2007 AT 11:07 PM
No visual oil leak/No blue smoke during an initial cold start-I will check the valve seals first something has to give.
The oil is in there, not leaking so it has to be burning and some of it has to come out of the tail end.
250miles on a qt is just way too muchy unless its brand new and undergoing breaking. An engine that burns a qt oil less than 500miles has a problem internally.
ITS TIME FOR THE WET/DRY COMPRESSION CHECK AND FOLLOWED BY A LEAKDOWN TEST TO GO FURTHER.
Monday, July 23rd, 2007 AT 8:31 PM
