1998 Toyota Corolla Electrical problem
1998 TOYOTA COROLLA
MARKROBINSON200
Electrical problem
1998 Toyota Corolla 110000 miles
When I turn my car on the daytime running lights come on and then about 10 seconds later (when the dashboard lights come on) the headlights go out. All fuses are fine. I think this may be a relay issue or a wiring issue. All other lights work. I have (so far) only checked this at night but I think it isn't a problem during the day... I *think* during the day everything may be working fine...
Does anyone have any advice about how to at least diagnose the problem more and see if I need to replace a relay or just have the wiring checked. How can I check the relay (if that's what the problem even is?)
Thanks,
Mark
Jan 15, 2008 at 10:24 PM
VOVIE57
How did you resolve your electrical problem ? Yesterday I shut off the car removed the key, opened drivers side door and buzzer went off. Also noticed parking,tail & dash lights are always on even with no key in ignition.
I have an 05 Toyota Corolla 78000mi.
Mar 16, 2008 at 6:31 PM
