Interior problem
1997 Toyota Corolla 4 cyl Two Wheel Drive Automatic
Hello, my dash lights are very dim now. Does anyone know what type of bulbs I will need to replace the old bulbs and how many. Thank You.
Thursday, February 19th, 2009 AT 11:26 PM
MMPRINCE4000
MECHANIC
Check your dimmer switch, if the bulbs are still working, it is more than likely the dimmer is bad.
The bulbs are not expensive, but you have to remove the IP (instrument panel), to get to them.
They may also be marked "replace as assembly" in which case you have to buy bulb and base.
