1996 Toyota Corolla No Ignition
MATRIX733
  • 1996 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 156,000 MILES
My sons toyota died while driving, no dash lights when key was turned. Battery is good, I check ground connection of battery and positive cable. Door locks works only because it is hooked directly to battery through alarm's brain. We left the car and fiddle with it a few hous later and it started. Drive it 1/2 mile home. Now it is dead again and no dash lights or power to the ignition system. Could it be an issue with the ECU? I just need guidance as to where to check for issues since the battery is good. We had to replace the key ignition cylinder a few years ago becasue a key broke in the old one. However, the key turns fine but no power is getting to the ignition system.
Thanks
Thursday, May 20th, 2010 AT 2:30 PM
Hi matrix733, welcome to 2carpros and TY for the donation.
Check the power distribution box and also all the fusible links to include the ignition switch.
Thursday, May 20th, 2010 AT 2:37 PM
MATRIX733
It turned out to be the main cable to the power distrubution box. It had broken off the battery connector. I saw it during my initial investigation but it looked black so I was not about to hook it up to power since black should be ground.
Its up and running now.
Thanks
Friday, May 21st, 2010 AT 7:12 PM
