1997 Toyota Corolla
SALMON79
  • 1997 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 120,000 MILES
Hi, my corolla is acting up! The car will not accelerate, its like if it miss fires just as you press the accelerator but if you press it slowly its ok? Also it seems to be a bit better when its cold!
thanks!
Monday, October 6th, 2008 AT 3:46 PM
MMPRINCE4000
  • 8,548 POSTS
Is your check engine light on? If so get the codes read and let us know.
Tuesday, October 7th, 2008 AT 6:18 AM
SALMON79
No engine light on! Would it sound like an air leak? Poor spark? Cat? The wrong plugs had been fitted to it for a few weeks but I have replaced them now with proper ones!
Thanks guys!
Tuesday, October 7th, 2008 AT 5:28 PM
MMPRINCE4000
  • 8,548 POSTS
The wrong plugs? Did they have any mechanical damage to them when you replaced them?
If they were misfiring, you could have overheated the CAT and clogged it. Have a backpressure test performed on the CAT.
Ususally a vacuum leak will cause a high idle.
Wednesday, October 8th, 2008 AT 7:03 AM
