1996 Toyota Corolla AC Quit Working
ZACKODOM
Air Conditioning problem
1996 Toyota Corolla 4 cyl Front Wheel Drive Automatic
My daughter's 96 Corolla's AC was working fine, then it just stopped. The light in the AC on/off push button went out when the AC stopped blowing cold air. Everything else seems to be working fine.
Aug 7, 2008 at 1:41 AM
SQUEELY413
[quote:e84b85a39b="zackodom"]Air Conditioning problem
My daughter's 96 Corolla's AC was working fine, then it just stopped. The light in the AC on/off push button went out when the AC stopped blowing cold air. Everything else seems to be working fine.[/quote:e84b85a39b]
Aug 7, 2008 at 12:26 PM
SQUEELY413
i do believe there is a fuse thats located in the engine comartment. look for a wire coming off the air conditioner and follow it and look for an inline fuse. it may also be a relay located in the fuse/relay box. check your manual for proper location of the relay and if you swap a good relay of the same in the box then that will/should solve the problem.....
My daughter's 96 Corolla's AC was working fine, then it just stopped. The light in the AC on/off push button went out when the AC stopped blowing cold air. Everything else seems to be working fine.[/quote]
Aug 7, 2008 at 12:29 PM
