Noises problem
1996 Toyota Corolla Manual 135000 miles
When I'm in gear but not accelerating, my car makes a rattling noise. I Think it's the exhaust pipe but it does not rattle all the time. What is it?
Thursday, July 2nd, 2009 AT 2:16 AM
MMPRINCE4000
MECHANIC
The rattle could be the clutch throw out bearing, this would be the car in neutral and clutch out.
Could also be a loose heat shield on the exhaust.
SPONSORED LINKS
Thursday, July 2nd, 2009 AT 7:08 AM
ANDYBURNER
MEMBER
I'v just had a new clutch fitted so do you think it could still be a clutch issue? After I replaced the clutch I thought the noise would stop. But it didn't.
Thanks!
Thursday, July 2nd, 2009 AT 7:34 AM
MMPRINCE4000
MECHANIC
If car is in neutral and clutch out and the rattle is there, then a throw out bearing, especially if the noise diminishes when you depress the clutch.
